S2000 Body and Paint Body kits, paint, ding repair and related discussions
Removing badges damage paint?
Old May 19, 2014 | 02:25 AM
1RM's Avatar
1RM
Default Removing badges damage paint?
Hey guys, I want to remove the S2000 side badges off my car. I have decided to just heat the badge with a hair dryer and then use some dental floss or something similar to pull it off.
My question is can a hair dryer actually damage the paint of a car? I tried to do one side and it wouldn't budge. I touched the panel after this and it was too hot to touch, so I thought I would find out some more info before i damage anything.
Old May 19, 2014 | 05:18 AM
stvS2K's Avatar
I used a heatgun and dental floss. With a heat gun you can definitely damage the paint, so you have to be careful. The badges on one side were really stubborn and it was difficult. When I finally got them off, I used goo-gone to break down and remove the residue.
My car is an '07 and the badges were stubborn, so I can imagine it is worse for older cars.
Old May 19, 2014 | 05:52 AM
1RM's Avatar
1RM
I used a hair dryer not a heat gun though
Old May 19, 2014 | 07:21 AM
DrakeValle's Avatar
It would take a decent amount of direct exposure from close range to cause damage with a blow dryer.
Old May 19, 2014 | 03:21 PM
jetboater's Avatar
I didn't use any heat---just 20 lb fishing line to "saw" the emblems off then goo gone to remove the residue. Too a while but didn't damage the paint.
Old May 20, 2014 | 01:16 AM
1RM's Avatar
1RM
FYI I managed to remove the badges using the hair dryer method.
I had a door from another which was ready to be thrown out, I decided to do a little test and see how long i could hold the hair dryer on the paint before it burnt. 1 minute and 40 seconds on high heat at a distance of 2cm from the paint and there was nothing wrong with the paint, just a little hot too touch.
Tried another part of the door with a heat gun which goes up to 600 degrees and within 15 seconds on high heat the paint begun to show little bubles and eventually lifted and turned brown.
Mr Moley
Aug 13, 2012 05:43 AM
joej
Aug 5, 2005 11:25 AM
s2kdriver80
Sep 16, 2003 06:33 PM
MacGyver
Oct 18, 2000 03:33 PM
