S2000 Body and Paint Body kits, paint, ding repair and related discussions
Whole car painted
Old Mar 11, 2011 | 03:10 PM
Kirpich's Avatar
Default Whole car painted
So I do all the prep, and a guy comes in and repaints my car. After all's said and done, there is a lot of 'trash' and orange peel on the surface of clearcoat. So I hand wet-sand the clear down, 1000, 1500, then 2000 grit sandpaper. Now, the question is:
How do I get rid of haze?
I have a variable speed buffer with a wool and some kinda foam pads. Also, 3M's Perfect-It rubbing compound. After I use it, there are still a lot of marks, and a slight haze over the otherwise nice smooth clear. What do I do?
Old Mar 11, 2011 | 03:26 PM
djbeatz08's Avatar
Use 3m machine polish(3m06064) and black pad. If its a black car you may want to use the ultra fina polish afterwards as well.
Old Mar 12, 2011 | 07:43 PM
Kirpich's Avatar
I was actually using Perfect-It II series rubbing compound, applied by a polisher machine, with wool. Is that the first step, or not? My 01 S2000 is yellow.
Old Mar 16, 2011 | 07:44 AM
irmos2k's Avatar
I have the perfect it 3000 which i believe is the 3000 grit compound, originally after spraying my rear trunk i used 1500 grit, then 1800, then wetsand with 2000, then a coarse compound with foam pad, and then the perfect it fine compound with the black pad, my trunk looks like a mirror, try doing that. It took me about 3 hours to prep and paint, then the next day, i sanded and buffed which took about 4-5 hours. so take your time and don't try to rush things
Old Mar 16, 2011 | 09:05 AM
k1ng124's Avatar
Compound, polish, then hand glaze is what I use.
Old Mar 26, 2011 | 02:09 PM
iam7head's Avatar
are you using a proper buffer? when you cut it with your black 3m foam pad does it heat up rapidly?
JTNY
Apr 6, 2009 12:34 PM
tlee1234
Aug 5, 2008 09:39 PM
mazman
Jun 26, 2003 01:39 PM
Hiroprotaganist
Jun 3, 2002 03:11 PM
rstark
Aug 31, 2001 08:50 PM
