Sponsored by: Sake Bomb
Adding negative camber on lowered S2000 ?
Old Jan 21, 2012 | 10:16 AM
Mr_Parky's Avatar
Default Adding negative camber on lowered S2000 ?
Can someone clarify if BOTH these parts are needed to achieve negative camber on a lowered s2000. Is the principle the same for front & rear.
For Front:
(1)Hardrace/Megan Front adjustable upper control arm
(2)Hardrace/Megan Front roll centre adjusting ball joints, with offset camber
For Rear:
(1)Hardrace/Megan Rear-Upper adjustable camber arms
(2)Hardrace/Megan Rear Roll Center Adjuster
Old Jan 21, 2012 | 10:59 AM
Chugs's Avatar
You don't need new control arms. Camber joints replace the upper ball joints in the front, allowing you more camber. The rear, on the other hand, can already achieve about -3*. If you need more, you could get this whole kit, for both front and rear. But for most cases, just a camber kit for the front is needed.
http://www.evasivemotorsports.com/me...000_Suspension
-Connor
Old Jan 21, 2012 | 07:30 PM
chetly's Avatar
Your wrong, the ball joints for the front shown go on the bottom.
I'm at -3.5 in the front with the J's version of these balljoints and the rear is at -3.0 with stock balljoints installed.
Not sure how much more you want.
Old Jan 21, 2012 | 07:58 PM
Chugs's Avatar
You're right, the J's and Megan/Hardrace go on the bottom, but the SPC joints I mentioned mount on the upper control arm.
-Connor
Old Jan 22, 2012 | 12:47 AM
Mr_Parky's Avatar
What bushes would you guys recommend changing while doing all suspension work, i.e. coilovers, sways, rca, bsk etc. Im thinking i might as well do the bushes while im at it. (car has 130k's)
RyanDavies
Mar 27, 2013 07:07 AM
Weasel497
Jun 11, 2012 10:27 AM
Mr_Parky
Jan 22, 2012 12:31 AM
TurboCongo
Jacksonville
15
Jan 26, 2011 08:39 AM
Wombo
May 17, 2009 01:03 AM
