Rear Camber Adjuster ?s (STR AP1)
Old Mar 27, 2013 | 05:49 AM
RyanDavies's Avatar
Default Rear Camber Adjuster ?s (STR AP1)
Couple of questions.
First, has there been any decision made on the legality of the SPC Camber Adjustment Ball-joints, either front or rear? I've come across random postings about them, just curious. I figure the standard now is the Hardrace / Megan Racing ones?
Second, in the rear, how much camber can be obtained typically from the stock adjusters (13in ride height)? If we went over to either the SPC or Megan joints in the rear, would that allow us to adjust camber without impacting toe (would save a lot of time on alignments)?
Thanks!
- Ryan
Old Mar 27, 2013 | 07:07 AM
robrob's Avatar
Thanks!
- Ryan
At 13" ride height you should be right around -3 max camber.
It would be difficult to align the SPC ball joint adjustment slot precisely enough not to affect toe. A 1/4 inch of total toe-in equates to 1/16 inch at the leading edge of one tire. If the leading edge of the tire moves only 1/16 of an inch as you slide the adjuster you're doubling your total toe-in.
Apex1.0
Aug 23, 2014 08:57 AM
DeletedUser05.22.20
Jun 27, 2014 03:59 PM
cookies28
Jun 21, 2012 08:14 PM
r8byb
Mar 17, 2009 11:00 AM
solomon
Jan 17, 2006 11:02 AM
