Sponsored by: Sake Bomb
Is this an alignment problem?
Old Jan 11, 2011 | 10:35 AM
Lummie's Avatar
Default Is this an alignment problem?
I noticed this when I was washing my car this past weekend. The passenger side rear wheel seems to sit closer to the rear bumper than the driver side rear wheel. You guys think this might be a problem with the toe setting? I hardly drive the car and haven't hit anything with it. I bought the car used with a "clean" carfax from the original owner. I measured the body panels and they're all the same length. Any advice will be appreciated!
I took the measurements from the body line at the bottom of the car to the wheel.
In front of driver rear wheel.
Behind driver rear wheel.
In front of passenger rear wheel.
Behind passenger rear wheel.
Old Jan 11, 2011 | 03:04 PM
JDMpearlwhyteZ's Avatar
im not expert..
but has the car been hit?? or jumped a curb??
that seems like some suspension damage..
Old Jan 11, 2011 | 03:14 PM
robinson's Avatar
Does the car drive oddly? If not, then I'm not sure I would care that much.
Old Jan 11, 2011 | 03:20 PM
Lummie's Avatar
Originally Posted by JDMpearlwhyteZ,Jan 11 2011, 04:04 PM
im not expert..
Not that I know of.
Old Jan 12, 2011 | 02:19 AM
Sukeetoshyoo88's Avatar
maybe you should get it checked out by an alignment shop.
i think you may have some suspension damage on your car.
Old Jan 14, 2011 | 09:41 PM
realblag's Avatar
You need to have the suspension checked. If that shows nothing, you need to have the frame measured at a good body shop (ie. not just some guy with a tape measure). Also,its difficult to tell, but from your pictures, it appears that the bottom edge of the fenders don't have the textured section. I think all S2ks had this. If yours doesn't, it means the fenders have been replaced.
I had a Civic with a salvage title. It had been hit HARD. The passenger side tire sat closer to the back of the fender on it too. I hope your problem is only bent suspension. It would be a shame to find something worse.
Old Jan 14, 2011 | 10:02 PM
RedCelica's Avatar
yeah that's not normal. I'd take it into a shop pronto
Old Jan 23, 2011 | 01:24 PM
blkwidow's Avatar
Looks like you have negative setback. Take it to a GOOD alignment shop and ask them to measure the setback. A bad shop will only measure camber castor and toe. If you have more then a degree of negative or positive setback then chances are it was in an accident.
Vtec dpn
Dec 11, 2018 02:44 PM
luchini
Oct 22, 2015 10:15 PM
TPhong
Mar 11, 2013 07:02 AM
bbs2z
Sep 2, 2012 12:47 PM
WRS2K
Jul 19, 2003 04:46 PM
