Sponsored by: Sake Bomb
Alignment results and weird steering
Old Jan 7, 2014 | 07:08 PM
Mangineer's Avatar
Default Alignment results and weird steering
Just like many people on this forum, I have coilovers which i installed myself and preloaded both coils and bushings. It drives ok on the street, but on the freeway the steering wheel feels as if it wants to keep steering more to the right if the freeway is turning to the right at 65+ mph.
I got an alignment finally and these are my specs..
Could this weird pulling feel be fixed? Should I adjust my alignment settings? If so.. How?
Old Jan 7, 2014 | 07:34 PM
Mangineer's Avatar
Maybe an FSB?? Btw its an 03,
Old Jan 7, 2014 | 08:48 PM
macr88's Avatar
Most likely just a tire issue, rotate the front tires side to side and see if the car pulls to the left.
If they're directional and it's raining where you're at then hold till it's dry, running a directional in reverse direction in the rain is not safe.
Old Jan 7, 2014 | 09:33 PM
Mangineer's Avatar
Yes the tires are directional, any other suggestions... FSB sounds like a band-aid to the issue... are my alignment specs ok???
Old Jan 8, 2014 | 05:35 AM
ZDan's Avatar
Agree with rotating tires left to right to see if it's a tire issue. First the fronts. If that doesn't change the pull, then swap the rears. If pull doesn't change direction, then tires are eliminated as the culprit.
FTR, from tests I've seen of running directional tires backwards, it makes practically no difference in wet grip. Still, you may as well swap them back after testing!
Alignment:
Looks symmetrical, good that they evened out the caster, but front vs. rear camber seems a bit extreme. With 3.5 negative camber in back, I would have preferred they evened out the fronts by increasing the rightside to 1-1/2 rather then decreasing left to 3/4. Knocking rear camber down to 2.5 would improve rear tire life a bit, too...
I also would have kept 0 toe up front and 1/8" in back. 1/4" will seriously impact your rear tire life. In my case, that much cut tire life in half actually made the handling more squirrelly (stock AP1).
Old Jan 8, 2014 | 07:06 PM
Gottabfast's Avatar
Check tire pressures too. Did they align your car with driver weight? Are your tires worn or wearing unevenly? Does the steering return to center well at low speeds and evenly left vs right?
Old Jan 8, 2014 | 07:16 PM
Mangineer's Avatar
Thanks ZDan... I think I will need to try the front tire swap.. Those tires came with the wheels soooo since I dont know the history of em.. It could be the culprit.. I might bring the rear camber back in a little bit as suggested..
Gottabfast.. Tires have adequate pressure.. I think new front tires might fix it since theyre old.. we shall see..
Old Jan 9, 2014 | 11:21 AM
RedCelica's Avatar
Id get that rear toe evened out to 1/8" on the right for starters.
Old Jan 9, 2014 | 03:08 PM
ZDan's Avatar
I'd bring the rear toe back down to 1/8" total as well, that will have a greater impact on rear tire life than the camber. I'd still bring the camber down to 2-2.5 as well
sillyboybmxer
May 5, 2009 09:40 AM
watchdogd
Sep 13, 2007 05:59 PM
FormerH22a4
Jun 9, 2006 05:45 PM
C4SxM5
Jun 17, 2005 06:47 AM
anishd
Feb 24, 2004 09:01 AM
