Alignment spec?
Hi, guys I need some advice for this setup please.
HKS coilovers, 17x9 +40, 245/40/17 all around and no sway bars (yet).
I was thinking about this spec. Is this good? And how you set your damper for street and track? likes how many clicks as a sugguest.
Front:
Camber: -2.5 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3.5 deg.
Toe: factory
Front:
Camber: -2.5 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3.5 deg.
Toe: factory
Front:
Camber: -2.5 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3.5 deg.
Toe: factory
Front:
Camber: -2.5 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3.5 deg.
Toe: factory
I have -2.5 up front and -3 in the rear. Toe is at 0 and I'm dropped pretty aggressively.
I think you will be OK with -3 or even -2.5 camber in the rear.
Originally Posted by GT Motoring,Feb 24 2010, 10:40 AM
We run -3 to -3.5 in front and -2.75 to -3.5 in the rear generally.
