anyone have 17x10 rpf1 with bbk?
Hi guys,
Does anyone know if the rpf1 17x10 +38 mm offset will clear the stoptech 328mm bbk?
The car is running downforce fenders in the front and will be running asm over fenders in the rear so I'm not terribly concerned about fitting it on stock bodied car. The tires will be 255/40-17
I asked Enkei about this one. They said:
We checked clearances on this one and found that this caliper interferes with the drop center. You would need at least an 9 mm spacer to clear the caliper.
Do you know if he was running stretched tires or 255/40-17? How far out did the wheel poke? Issues with the steering wheel at full lock or suspension at full compression?
jirro22
05-15-2012 05:42 PM
