Axle/Differential bolts
Hello, I wanted to know if the size of the bolts that come with the axle/differential spacers are the same as the OEM. My car came with an Megan axle spacers and Megan coilovers. I have bought the OEM suspension to go back to stock and need to know if the bolts and nuts on the axle spacers can be used once the spacers are removed.
Thank you
Thank you
purchase new bolts and nuts from the hardware store or Honda. the nuts are crush nuts and supposed to be one time use.
OEM bolts are shorter than the ones included with spacers.
I took this from the majestic diagram:
90181-S2A-000 013 012 BOLT, FLANGE (10X26)
94050-10080 015 012 NUT, FLANGE (10MM)
I might almost say just by them from Honda, they're not that expensive. Probably $3.oo for each bolt and $1.oo for each nut at your local dealership. Otherwise you could buy bolts from your local hardware store in the 10x26 size.
