Running 5mm spacers with OEM studs/bolts?
Old Dec 30, 2007 | 09:22 PM
S2FARSI's Avatar
Default Running 5mm spacers with OEM studs/bolts?
I just bought some H and R 5mm spacers and dont want to go through the hassle of replacing the wheel bolts. I was wondering if it would be safe to use the spacers on OEM bolts (or whatever they are called). Keep in mind I am using after market wheels and after market closed ended lug nuts.
Old Dec 31, 2007 | 02:20 PM
Voodoo_S2K's Avatar
I believe Honda stud threads are 1.5mm pitch, so you would be losing just over 3 full turns of engagement. That's more then I would personally be comfortable with.
Old Dec 31, 2007 | 04:29 PM
chino101's Avatar
The stock lug nuts have about 8 threads engaging the studs, if you still get 8 turns of engagement, you are OK.
Rule of thumb dictates that there should be "one diameter of threads engaging the studs. "
For example Honda uses 12mm diameter studs, therefore 12mm of threads should be engaging the studs which equals 8 turns/threads.
Then again "German standard requiring 6.4 threads to be engaged on 1.5mm pitch steel fasteners, for a total of 9.6mm."
Ref: http://www.sportcompactcarweb.com/tech/020...uide/index.html
Old Jan 1, 2008 | 07:24 AM
daverx7's Avatar
I know that I tried going with the Honda studs with the 5mm spacers, but in my particular case I saw some stress on the threads after just scrubbing in some new tires. So, I went ahead and swapped out the studs. Man, that was more expensive than I hoped for, tho.
Good luck!
-Dave
Old Jan 1, 2008 | 01:24 PM
S2FARSI's Avatar
Wanna share?
Old Jan 1, 2008 | 02:09 PM
daverx7's Avatar
Here's a thread that confirms why.... that is if you don't do the work yourself, like me.
https://www.s2ki.com/forums/index.php?showtopic=374241
-Dave
ateens4
Feb 7, 2015 07:39 AM
travanx
May 15, 2013 08:30 AM
Nugy
May 30, 2011 10:24 PM
astig2k
Apr 19, 2008 02:42 PM
phils2k
Mar 27, 2008 09:40 AM
