Buddy Club front RCA reviews?
#21
As I mentioned before, I don't need more camber, I just want to correct the roll center.
And for that a spacer with the OEM joint is equally effective as a new joint like Hardrace.
A 3d model and a dxf file is no problem for me, a friend has a milling machine and I still have some aluminum left which I could use.
That is the easiest way for me.
Mybad. I misread it as you DO need.
Yeah, if you got access to all that equipment, and you don't need camber ....then I can't imagine why a plate for the OEM joint wouldn't work.
Longer hardware can't be that hard to come by either.
Let us know how it turns out.
#22
But I don't know if I still can get it done this season. And my plan would be to install rear RCAs as well.
Or does it make sense to use RCAs only in the front?
#24
I don't think it makes sense just to use front RCA's. But a lot of people use big front sway bars or just front RCA's to make the car understeer prone.
Kami Speed
30
06-26-2008 10:01 AM
