Sponsored by: Sake Bomb
Caster problem
Old Jan 30, 2018 | 12:28 PM
ThiggeR's Avatar
Default Caster problem
Hi guys, I'm having a problem achieving 6° caster, I'm running ohlins, hard race front and rear camber arms, hardrace rear toe arms and fully polybushed, I had the geo done today and the most they could achieve was 3.3° one side and 4.7° the other so I settled on having them the same at 3.3, I set the front camber at 2.7 with 0 toe and 3.2 rear with. 25" toe, any insight as to why the caster won't adjust would be greatfully received. Thank you
Old Jan 30, 2018 | 01:52 PM
twohoos's Avatar
Classic symptom of a bent lower control arm. Generally not visibly bent, so low caster is actually the main indicator. But just cause you don't see it, don't be fooled: this car should hit 6deg caster all day every day.
Apex1.0
Aug 23, 2014 08:57 AM
DeletedUser05.22.20
Jun 27, 2014 03:59 PM
MB
Mar 13, 2013 02:36 PM
cookies28
Jun 21, 2012 08:14 PM
p0pe
Dec 7, 2004 07:07 AM
