Sponsored by: Sake Bomb
caster settings
Old Feb 14, 2011 | 02:31 PM
dirtykoala's Avatar
Default caster settings
i took my car to wheel works for an alignment today. they set the caster at 7.5, is that too much? the car feels ok to me.
other settings were:
Front-
camber: -1.1 left and right
toe: 0.00
caster: 7.5
Rear-
camber: -2.5 left and right
toe: 0.00
does everything else look good?
Old Feb 14, 2011 | 04:14 PM
robinson's Avatar
You sacrifice camber with that much caster. The choice is up to you and what you want.
Old Feb 14, 2011 | 04:19 PM
cuonice's Avatar
.... but gain dynamic camber.
0.00 rear toe seems a bit out of order.
Old Feb 14, 2011 | 04:21 PM
dirtykoala's Avatar
im happy with my front camber settings right now, is that a good amount of caster if im happy with the camber? and what rear toe setting would be good?
Old Feb 14, 2011 | 04:29 PM
cuonice's Avatar
Typical settings range from .12 to .30 degrees of total toe in. You don't have to be confined by what others consider normal or acceptable though...
-Aaron
Old Feb 14, 2011 | 05:04 PM
RedCelica's Avatar
I personally would put the caster @ 6 deg., and 2.0f and 1.0r camber.
Old Feb 14, 2011 | 05:51 PM
dirtykoala's Avatar
thanks. ill probably get the alignment redone after i lower the back a little bit.
im worried about excess tire wear from too much toe.
my camber settings are as least aggressive as possible right now with my spacers and ride height.
Kaneda215
Aug 11, 2011 09:16 AM
irock aypee one
Dec 16, 2006 11:46 AM
530s2k
May 16, 2006 01:19 PM
S2K:-)
Apr 13, 2006 08:31 PM
exceltoexcel
May 5, 2004 09:29 AM
