Sponsored by: Sake Bomb
View Poll Results: If I drop my car another 1/16" in the front after my alignment, what will change?
Nothing, and even if it does it won't be noticeable... you fool
42.86%
Caster
0%
Camber
14.29%
Toe
14.29%
A combination of 2, 3, and/or 4
28.57%
Voters: 7. You may not vote on this poll
Minor Ride Height Change with Alignment?
Old Aug 10, 2011 | 01:25 PM
Kaneda215's Avatar
Default Minor Ride Height Change with Alignment?
I recently slapped on my Bilstein PSS and dropped it to about a 1 finger gap all around (I have specific measurements I've been keeping but I won't bore you with them). I've been on the quest to get perfect ride height all around +/- an 1/16 of an inch (I know it sounds minute, but I notice it). I had to me a perfect ride height and I feel as though after my alignment, it's slightly out of whack.
Before Alignment (after installation)
Front Left
Camber: -.9
Caster: 7.6
Toe: -.27
Front Right
Camber: -.1.4
Caster: 5.4
Toe: -.25
Rear Left
Camber: -2.2
Toe: .38
Rear Right
Camber: -1.8
Toe: .22
After Alignment
Front Left
Camber: -.7
Caster: 6.3
Toe: 00
Front Right
Camber: -.7
Caster: 6.2
Toe: -.01
Rear Left
Camber: -2.0
Toe: .11
Rear Right
Camber: -1.9
Toe: .15
I'm mostly worried about my FL/RL height now. I feel as though the front has moved up 1/16" and the rear has moved down 1/16". It makes sense since the caster in the FL was reduced, thus making the ride height a little higher.
My questions:
Would an alignment like this shift the ride heights 1 or 2 1/16"?
If I drop the FL down the 1/16", and raise the RL 1/16" how much would that change my alignment?
Thanks a bunch.
Old Aug 10, 2011 | 01:44 PM
Mike21's Avatar
It shouldn't change too drastically, but changing the ride height will throw off all of your alignment settings slightly. Will it be noticeable? Maybe, maybe not. But your tire wear will tell you that. I don't have enough experience with alignments to tell you how bad it will throw it off.
Keep in mind that toe is what really destroys tires.
Old Aug 10, 2011 | 06:06 PM
Kaneda215's Avatar
lol, bump guys? Someone's gotta have some insight on this?
Old Aug 10, 2011 | 06:20 PM
Carbon Blue's Avatar
im in the same boat, do you have pics of your current setup kaneda? I would love to see some pics, are you maxxed out on the drop or do you still have some left? thanks
Old Aug 10, 2011 | 11:17 PM
nbaning's Avatar
Old Aug 11, 2011 | 07:57 AM
Kaneda215's Avatar
Bump, I really want to fix this ride height but will leave it if the alignment gets thrown off too much.
Old Aug 11, 2011 | 08:31 AM
kimimila's Avatar
Just remember that the S is designed to be slightly higher on the drivers side with out the driver, when a driver is in the car, the car will then be level.
Old Aug 11, 2011 | 09:16 AM
Kaneda215's Avatar
True, but this is more of a front/rear problem.
irock aypee one
Dec 16, 2006 11:46 AM
Hitman
21
Nov 29, 2005 01:40 PM
exceltoexcel
May 5, 2004 04:15 PM
exceltoexcel
May 5, 2004 09:29 AM
CMiS2K
Jun 11, 2003 06:08 PM
