Sponsored by: Sake Bomb
Center Bore & offset
Old Nov 3, 2010 | 06:18 AM
scipion's Avatar
Default Center Bore & offset
Hi,
I have a full set of Brembo brakes came from a Subaru Impreza STI MY09. (4P callipers - front with 330mm rotors, 2P callipers - rear with 320 rotors).
Does anyone know if i can fit this set to a S2K? I want to know what is the center bore diameter and offset of a S2K.
Thanks
Old Nov 3, 2010 | 07:55 AM
1nate7's Avatar
It will only work with a lot of custom fabrication.
Old Nov 4, 2010 | 08:35 AM
BrakeExpert's Avatar
I believe the front rotors on a subaru are somewhere around 50 something millimeters, they can't fit without being bored out. I had to do this with 05 STi rotors to fit them to a legend, they wont fit the S2k hub.
The front and rear calipers CAN fit with lots of modification, but your rears will not have a drum e-brake. You'd have to fit in a drum e-brake (there is no room) or get those plastic brembo calipers that are just for the e-brake. Honestly I'd sell em and spend the money on something like the RL front upgrade, and spend the rest toward better pads and bigger, wider wheels with performance tires.
Fat
Nov 22, 2016 11:37 AM
edumak
Oct 14, 2016 03:07 PM
jaeyon00
Jul 6, 2009 02:07 AM
JSR_AP2
Jan 12, 2007 05:24 PM
vteconly
Apr 6, 2005 09:29 AM
