Do Acural TL brembos fit?
Old Jan 12, 2007 | 07:20 AM
JSR_AP2's Avatar
Default Do Acural TL brembos fit?
Wondering if the Brembos on the new Acura TLs fit the S2000?
Will it bolt up or is a custom bracket needed?
What size are the brembo TL rotors (diameter and width)?
How much clearance is needed for the TL Brembos (distance from rotor face to furthest point on caliper)?
Thanks for the help!
JSR
Old Jan 12, 2007 | 01:19 PM
Ks320's Avatar
It's generally not a good idea to use brakes that are designed for another car ...
Buying a Brembo BBK will probably cost around the same than getting the OEM parts for the TL + all that hassle ... !?!
Old Jan 12, 2007 | 04:07 PM
JSR_AP2's Avatar
Used calipers can be quite cheap and if the TL calipers are smaller and thinner (require less wheel clearance), it may be a better option. If it fits physically, I'll look more into the piston area. But no need to do that if it doesn't fit or requires the same clearance as other BBKs.
Old Jan 12, 2007 | 05:18 PM
clawhammer's Avatar
Why don't you buy a pair on ebay and try to make it fit?
If it doesn't work, you should be able to sell it for around the same price you paid for it.
Old Jan 12, 2007 | 05:24 PM
topekoms's Avatar
i took brakes off a porsche carrera s and put it on my bmw z4...easy
custom bracket..only cost a few hundred for labour....putting it on alone is only 100 bucks
Atr-platti
Aug 5, 2015 10:14 PM
S2KiChad
Jul 23, 2014 02:51 PM
sean2sean
Feb 25, 2007 09:22 AM
SiDHEaD
Jan 11, 2007 08:32 AM
S2OOO
Jun 27, 2003 04:35 PM
