coilerovers for approx $1,200
#21
You don't need stiff springs unless you have aero, etc etc.
For an otherwise stock S2000 (with tires/brake pads), the PSS/9 spring rates work well...and the shock provides good control for transitions.
Bilsteins or Ohlins can make the car a bit faster than the stock suspension as they sit. Both will improve confidence and feel and maybe make the car easier to drive, which will help you go faster. And yes...the Öhlins will magnify that "goodass feeling" (my technical phrase).
But even then...neither are likely going to shave a *few* seconds off by themselves. And at that level....an off the shelf Bilstein car isn't going to be inherently faster/slower than an Öhlins car.
This is my experience.
#22
Not sure if you a preparing for your first event or not but i highly recommend you go with stock shocks. Change your fluids, pads, buy some nice tyres, go get an alignment done and go and have fun. Learn the track and its lines and then come back and then ask yourself 'What is making me feel not confident to drive harder?' Then start looking for a solution. I think you are looking for a solution without really having a problem to solve.
Additionally having coilovers adds a lot more variables to think about when trying to answer that question. Keep it simple, alignment changes are difficult enough to learn as is.
#24
I've done my share of HPDEs in the past in various BMWs with stock and aftermarket suspension, both c/o systems and lowering springs w/ upgraded shocks. I like having the option to stiffen up or soften the ride quality and I would like to lower the car a little. Camber adjustments can help tailor to a driver's style as well. My approach isn't to throw an unlimited budget at my car, but rather make subtle improvements for daily driving and the occasional track day event. Considering I already have 90K mi on the OEM suspension, adding new components should be an improvement.
#27
You can't adjust camber with the shock mount on a double wishbone car.
The car has factory camber adjusters underneath the car, at the LCA's. As well as toe and front caster adjusters.
You need an entire alignment when you adjust camber. You don't want to do a camber adjustment by itself, trackside, if that's what your goal was. Camber adjustment on virtually any vehicle will also result in other angles changing because of geometry.
#28
If you have hpde experience and you are on rs3s or stickier, you will want more spring rate then you get from the pss. If you want springs around 500-600lb, adjustable damping and not complete crap. Koni/gc is a great setup. Maybe look into fa500 also.
#30
Tein Monosports are pretty good, I've ridden in a car with them. Not too sure about how long they last but they certainly perform well. Some shocks in that price range get overwhelmed especially with hard continuous turns with bumps. The HKS hipermax GT are also decent around that price point.
