Considering return to stock suspension
Considering returning to stock suspension. I have a MY03 with Koni shocks and CR springs, front sway bar (don't know the brand, something aftermarket-it's red) and front strut bar (bought the car this way). Like ride height but ride is too rough and there is a bit of drive steer. I don't track it and only drive it for leisure. I have the stock suspension which has about 90k on it. Is there any benefit to switching to a stock suspension from a later year or are the AP1 shocks fairly comfortable? Thinking I might want to keep the CR springs. Thoughts? Should I switch the sway bar back to stock also for better comfort? Thanks in advance
you could do a mix-n-match of your oe and CR springs with the konis on the lower perch to get the slightly lower ride height you desire with the handling change you desire. I'm not familiar with term "drive steer" though. The red anti-roll bar is eibach. Are you on stock staggered wheels or a square setup?
you'll find the OE and CR spring and ARB rates here
https://www.s2ki.com/s2000/topic/818...nsion-springs/
eibach ARB info here
https://www.s2ki.com/s2000/topic/822...y-bars-review/
Ap1 or ap2? I know there are technical differences. I had an ap2 before and know that was pretty smooth. I haven't spent much time behind the wheel of an ap1 with a stock suspension.
I went from stock 2002 spring & shocks to CR springs and Koni. The ride barely changes, if not better, mostly due to the Koni shocks. You should keep the current combo; I like the balance of the CR spring bias.
The Koni shocks ride better over bumps, for sure. They also have more low speed damping, so transitions like braking or swerving don't upset the car the way stock shocks do.
I ended up going back to stock springs (keeping Koni) just to stay legal in my autocross class.
I would try changing the rebound adjustments on the konis. The Koni sports have a digressive compression valving curve, that can improve the ride/handling over the stock showa shocks. The Koni are on par with the quality of the oem shocks but with better valving. You may actually take a step down in the ride department by going stock.
Try running the Konis closer to full soft. If you start to get to many oscillations, stiffen them a little.
Honda made annual (?) suspension/wheel/tire changes during the production life of the S2000. I can only assume these were improvements and the '04 suspension was at least incrementally better than the '03 etc. If you have your stock suspension just re-fit it, otherwise look for a complete set (including wheels if yours are different) from '03 or later.
-- Chuck
-- Chuck
