Sponsored by: Sake Bomb
CR springs ,height problem
Old Apr 22, 2013 | 07:28 PM
EVLS2K's Avatar
Default CR springs ,height problem
Hello, boys and girls
MY 01 ,i kept the shocks and replaced only the springs with CR ones
The rear has a 2.5 finger gap and the front is more like 4 finger plus
I will post a pic tomorrow
Thank you
Old Apr 22, 2013 | 07:51 PM
Carbon Blue's Avatar
did you preload the control arm bushings when you tightened everything down?
Old Apr 23, 2013 | 10:35 AM
EVLS2K's Avatar
I dont know.a friend swapped the springs
Old Apr 23, 2013 | 10:40 AM
BEASTMODE's Avatar
CR springs are known to sit much higher in the front.
Old Apr 23, 2013 | 11:38 AM
Anarchy's Avatar
Just the way CR suspension sits
Old Apr 23, 2013 | 04:38 PM
hai1206vn's Avatar
I just did the swap last month into my '02 AP1. Virtually identical height before and after.
Old Apr 23, 2013 | 10:51 PM
Reid's Avatar
This.
I installed my CR springs/shocks on my AP1, and they will sit very high in the front if the suspension isn't preloaded when tightening the fasteners.
Old Apr 24, 2013 | 08:30 PM
EVLS2K's Avatar
Thank you guys
I will redo them and let you know
Old Apr 25, 2013 | 05:32 PM
yea, make sure to loosen the top two control arm bolts and compress the shock to your desired height (measure from center of hub to tip of the fender) and then tighten the control arm bolts to the correct torque.
Old Apr 26, 2013 | 03:36 PM
EELPIE's Avatar
AP1 with CR shocks and springs. No visual difference from stock AP1. Yeah maybe if you measure, the CR stuff leaves you a little higher. But if you can tell with out measuring, you need to take your eyeballs to NASA or Lockeed Martin they can use someone like you. To the OP my guess is as stated, the suspension was tightened without being loaded (car on the ground or jacks used to load if in the air).
myflys2k
Southern Ontario For Sale
Aug 9, 2016 06:42 PM
TraxxofAOT
Jul 23, 2015 06:21 AM
S2KJohnG
Jun 10, 2013 01:33 AM
m carter
May 31, 2013 12:46 PM
merckx racer
Aug 25, 2010 07:47 AM
