Cusco Front Sway Bar Bushing Fitment Not Flush
I purchased a Cusco FSB from GoTuning a couple months ago and have issues with the bushings not fitting properly. After contacting GoTuning, it seems that I got the correct bushing from Cusco (they confirmed it was correct, and the bushing itself has the 32mm marking on it, and I measured it as well). However, the bushing looks like it is being squished when tightened down like in the photos below. I tried reinstalling it again recently, and found that before tightening the bracket down, everything fit pretty well. However, it seems that because the bracket is meant for the stock bar, it is a little too small for the added thickness/girth of the thicker bar and bushing. So when the bracket is tightened all the way, the bushing deforms (if that makes sense). Does anyone have any suggestions on how to fix this? I was thinking maybe a small spacer between the bracket and the frame would work
Thanks in advance
Thanks in advance
Are you sure you put the one that came with it on? That looks pretty dirty for a brand new bushing. I have the same stabilizer bar and I never had that issue with the bushings that came with it. I've since switched to Prothane poly bushings and will have to check that I didn't accidentally toss the ones that came with it.
Do you have more information about which prothane bushing you got? Did you just get their universal bushings for sway bars? Greasable/nongreasable? They look similar to energy suspension but the website is hard to navigate
The bushing is being pressed apart. It is either that the bracket is pushing it against the mount causing the 'squish', or the bar is. The bracket should keep in place.
Have you tried loosening the bracket, disconnecting the bar from the lower A-arms, and retightening the brackets making sure they are pressed open? If necessary, a reinforced tape or wire could be used to hold them closed while tightening the bracket but it shouldn't be necessary.
Is it possible the bar is bent causing ti to push the bushing open?
Is the bar centered? All the pictures are from the driver's side. Is the bushing ok on the passenger side? If the bar isn't centered it is possible that bend on the end is starting in or before the bushing causing the problem.
Originally Posted by Fokker' timestamp='1435387446' post='23662338
There isn't a way to install them upside down.
These are the front bar bushings and factory brackets. I had no pinching issues when I was using them.
probert
11-25-2003 07:49 AM
