eibach pro kit
eibach pro kit
i want to lower my car on the stock struts/shocks. and i wondering will i be safe on the eibach prokit as far as strut life? will the strut life be reduced? will i notice any handling difference. i like the 1inch drop because i still have my oem ap1 rims on but i want to get something simliar to ap2v1 rims. i wanna run a 255 in the rear and a 225 in the front tire width. would i be okay with that with this 1 inspring drop...also will i need anthing else? rear shaft spacers?. camber kit?
Originally Posted by s2k aok,Jan 17 2010, 11:54 AM
don't need shaft spacers or camber kit either...
Just be prepared to have to replace items.
How much mileage do you have on your 2001 S? It's possible that your stock shocks/struts are already on their way out if you have more than 80-90k miles on them. I would look into some reliable coilovers...Like the Bilstein Pss9's.
Ya since your car is 8-9 years old, I'd think about getting a set of shocks to go w/ the Eibachs
I'm putting the Eibachs on my stock shocks and plan on them lasting for a while, but my car is only 10 months old so the shocks should be in perfect condition
PSS9's are supposed to be one of the best DD coilovers on the market. Do a search on them. Virtually no bad reviews...Most reviews are positive.
Even though your car is 8-9 years old your shock/struts don't have enough mileage on them. This choice is up to you on whether you want to change your shocks/struts out along with springs. The only thing I can advise you of is if you do decide to change out both at the same time it would be best to change them out with a set(shock & spring combo) that have been engineered through R&D to work in unison with each other(coilover) no matter what coilover you choose to go with(along with the height adjust-ability as a bonus). My suggestion of a coilover for your driving style is the Bilstein PSS9's.
bumpinvtec
02-06-2009 12:18 AM
