Sponsored by: Sake Bomb
HELP! Brake replacement
Old Jun 23, 2010 | 12:09 PM
saxtonsS2k's Avatar
Default HELP! Brake replacement
my s2000 has 40,000 miles on it, It has the origional OEM brakes adn they began to squeak would you recommend replacing both the pads and rotors or should the rotors still be fine? can i get away with just replacing the pads? please voice your opinion
Old Jun 24, 2010 | 11:00 AM
Mrfixit687's Avatar
Replace the pads, and machine the rotors.
Old Jun 24, 2010 | 01:11 PM
ZDan's Avatar
How much friction material is on the pads? If it's more than the thickness of the backing plate, you might just try some antisqueal grease or goop on the backside of the pads.
Replacing rotors shouldn't affect squeaking/squealing.
I wouldn't bother having rotors turned. If they're thicker than the min. thickness, just leave them alone.
Old Jun 24, 2010 | 01:41 PM
camuman's Avatar
x2. couple bucks for the goop and you put it on. does wonders.
TheSoundMan21
Mar 1, 2010 02:11 PM
s2sik
Feb 7, 2009 03:51 PM
Driven
Oct 21, 2008 01:30 AM
Porsche951
Mar 16, 2006 04:01 AM
s2k_redhead
May 20, 2002 05:30 PM
