Sponsored by: Sake Bomb
I keep blowing a shock!
Old Feb 21, 2010 | 08:24 PM
omg_miiiike's Avatar
Default I keep blowing a shock!
I have an 01, with 111k on it right now.. The suspension was stock until a few months back, I installed AP2 shocks with Tein springs.. The springs did lower the car more than I thought they would, and I eventually blew the drivers side front shock.
I replaced it, and blew it again.. Is there a reason it's always that shock? I'm not a total idiot, but I avoid everything I should avoid in the roadway including small children; and it still blows..
The last shock I got I believe had 43k on it also. Any idea why it may just be that one??
Old Feb 22, 2010 | 09:43 PM
realautohaus's Avatar
I would use new shocks and call it a day. You can never tell what you get with used shocks. :s Atleast, if the new one breaks you got warranty. Take it to a reputable shop and get ur suspension checked. Goodluck!
Old Feb 22, 2010 | 09:51 PM
PsykotiK's Avatar
just get konis.. they'll be warrantied
Old Feb 26, 2010 | 03:42 PM
Race Roots's Avatar
Banned
I agree with Psykotik..... Your best bet is to invest in a performance shock that can handle lowering springs and the harsh roads.
Old Feb 28, 2010 | 07:53 AM
lawliver's Avatar
not sure why you keep blowing the shocks but they will continue to do so because you have oem shocks on different springs which are not designed for
Old Mar 1, 2010 | 04:27 PM
RacingEmotions's Avatar
quit cheapin out and get new ones so they'll last you longer. if you're smart about it, get some koni yellow's so that you have a shock made for lowered cars
Old Mar 1, 2010 | 11:06 PM
Spitfire8o5's Avatar
1pc coilovers are worth the money... save up some cash man
Old Mar 2, 2010 | 06:10 AM
an2ny's Avatar
Hi Mike, is the shock leaking? It did have around that 42K of highway use. Do you drive the car hard? Do you daily drive it? Do you hit a lot of pot holes? Maybe there is something wrong with that specific spring, but it will be hard to tell.
Maybe a set of coilovers should help, or koni yellows with your springs.
Old Mar 3, 2010 | 10:26 AM
dfvs2k's Avatar
Aftermarket spring with OEM shock will not last to long. That combo will contribute to blowing the shock.
You should have learned from the first incident.
Old Mar 3, 2010 | 03:25 PM
Billj747's Avatar
Lowering springs on the stock shocks reduce suspension travel without increasing spring rate much. If you hit bumps and bottom out the shock, you will kill it.
I don't really agree that the slightly higher rates of a lowering spring will put demands on the shock alone to kill it. So its either you're bottoming out or have bad luck buying used stuff.
Billy
Low_Key_Slaps
Feb 6, 2019 11:24 AM
s2konroids
Feb 8, 2009 06:26 AM
s2konroids
Sep 29, 2008 03:11 AM
ebeldesign
Sep 29, 2006 09:22 PM
ericlikewhoa
Aug 6, 2006 03:14 PM
