Sponsored by: Sake Bomb
Koni Yellow Washers
Old May 10, 2017 | 09:08 AM
yourboysoap's Avatar
Default Koni Yellow Washers
I am in the process of installing koni shocks and something just doesn't make sense. I got a full set of Koni yellows and the washers do not fit over the stem. I do know per DIY write-ups on here that you are supposed to drill out the washers/bushings to go from the stock suspension over to the Koni shock.
However, even the washers provided by Koni do not fit over the stem so in any setup scenario, those washers do not fit without modification. It also appears that the washers provided by Koni are direct replacements for what would move over to the new shock but it just blows my mind that Koni would provide washers that have no chance of fitting. What's up with that and have any of you also experienced this?
Old May 10, 2017 | 09:19 AM
JBamin's Avatar
any chance you can post up some pics?
Old May 10, 2017 | 09:32 AM
B serious's Avatar
While literally trillions of humans have installed Koni Yellows...you may not be finding info on your issue because:
-Nobody else has had this issue.
-It is not an issue; you're just not understanding the directions.
-Your particular set has been incorrectly packaged.
A photograph of your issue would help.
None of the washers except the plastic "caps" are supposed to go past the bumpstop...stopper...thing (technical term).
Old May 10, 2017 | 10:29 AM
Sure guys. Thanks. I was honestly wondering if someone would say "yeah thats how they are" and that would be that.
I uploaded some images here and i put captions under each picture for what I am talking about: http://imgur.com/a/CW3Re
Also, I am referencing this DIY: https://www.s2ki.com/forums/s2000-un...lation-303417/ which says to drill out 8 rose bushings and 4 dust covers. Picture of that here:
What am I ****ing up here?
Old May 10, 2017 | 10:37 AM
I'm starting to realize what I may have misunderstood. Is it supposed to go:
hi hat
dowel
washer
-WELD ON SHAFT-
bumpstop
plastic cap
Shock
That would make sense as to what I misunderstood here.
Old May 10, 2017 | 10:43 AM
B serious's Avatar
hi hat
dowel
washer
-WELD ON SHAFT-
bumpstop
plastic cap
Shock
edit: wait...what dowel?
^correct. No washers go past the welded on bumpstop stopper.
Old May 10, 2017 | 10:44 AM
I feel pretty dumb but at least I didn't drill em all out. Thanks!
Old May 10, 2017 | 10:47 AM
B serious's Avatar
No problem! The setup wouldn't have worked properly if you drilled them. I assumed the issue was some misunderstanding as to how far the washers go. Koni's instructions are..."excellent".
Also, I edited my post. Which dowel are you referring to?
Old May 10, 2017 | 10:54 AM
I might have been calling it by an incorrect name. The cylinder that slips over the top before the hihat goes on.
Old May 10, 2017 | 11:28 AM
B serious's Avatar
There shouldn't be one of those in a S2000 application. That's strange. Does it fit inside the bushing?
The stock tophat (hihat) does not have this dowel. The bushings are metal reinforced.
Or is this some sort of spacer?
