Sponsored by: Sake Bomb
Need help disassembling tein coilover
Old Mar 12, 2012 | 06:43 PM
cinaibur's Avatar
Former Sponsor
Default Need help disassembling tein coilover
I'm trying to replace the springs on my Tein Comfort Sports with shorter springs from Swift. I can't get the top nut off of the strut. It just spins and spins and spins. Is there any trick to getting this off? I don't have access to an impact wrench.
Old Mar 12, 2012 | 07:54 PM
JunD's Avatar
If I remember correctly, I might be wrong, you need to remove the adjustment knob at the top. Stick a allen wrench into that hole and use a closed end wrench to turn the nut off.
Old Mar 12, 2012 | 07:58 PM
99SH's Avatar
Take a close look at the topmost portion of the threaded part of the shaft. There is a flat spot which is used to place a wrench on as you undo the nut.
Old Mar 12, 2012 | 09:33 PM
Croc's Avatar
this ^^
Old Mar 13, 2012 | 05:10 AM
cinaibur's Avatar
Former Sponsor
Thanks. I'll give this a shot tonight. I might have a line on an impact gun I can borrow later this week if this doesn't work.
PS - I got a call back from Evasive (where I bought my Swift springs), there was a mistake about the stock of Swift springs and they don't have them. However, they did have the exact same spring from Tein for $117 cheaper! FYI to anyone looking for 65mm I.D. springs...
Old Mar 13, 2012 | 07:27 AM
99SH's Avatar
Don't. You can potentially damage a seal as you spin the shaft at a high rate. Not worth it...
Old Mar 13, 2012 | 08:36 AM
Croc's Avatar
Tein say not to use impact gun!
Old Mar 13, 2012 | 09:44 AM
cinaibur's Avatar
Former Sponsor
Ok. Thanks for the heads up. I bought an open end crowfoot wrench on lunch break so I'm going to give this a try tonight.
Old Mar 13, 2012 | 05:52 PM
99SH's Avatar
Why not keep it simple and use a box end wrench?
It's difficult to apply force using a crowfoot wrench whilst holding the shaft steady with the other hand. If you're hard set on using a crowfoot, I recommend a flare type crowfoot to mitigate any collateral damage on the nut.
Old Mar 13, 2012 | 06:28 PM
cinaibur's Avatar
Former Sponsor
Crowfoot worked just fine. No damage to the nut. Thanks for all the help.
rondnoir
Apr 11, 2013 12:46 PM
murderedrsx
Oct 9, 2011 06:06 PM
Jiggy
Mar 29, 2011 05:42 AM
ClayMan28
Nov 12, 2010 12:00 PM
REVN29K_LAC
Aug 8, 2007 12:27 PM
