Need help with ES bushings.
I'm currently in the process of replacing my bushings with ES bushings. The problem I'm having is with the instructions on the lower control arms. I've seen 2 different instructions from Energy Suspension 1 saying to reuse all 3 outer sleeves and the other saying to just reuse the strut position outer sleeve. Any help would be appreciated.
If you measure the diameter on your new bushings and compare that to where they would mount it should be obvious.
Pretty sure the bigger ones needs to have the sleeves reused though.
You really shouldn't use poly for the the strut bushing as it will most likely get deformed after not that long use.
Just keep the stock rubber one there.
