Sponsored by: Sake Bomb
Ohlins DFV Shocks installed
Old 04-24-2013, 10:15 AM
grubinski's Avatar
For my application, I'm fine with the rates as is. This is my daily driver, and I'll use it to take LONG road trips in the summer. It will probably only see the track 4-5 times a year at most ... no point in totally track-biasing the setup given my usage.
That's also why it's got Michelin Pilot Super Sports on it instead of RE11s or similar tires.
Old 04-24-2013, 10:46 AM
RedCelica's Avatar
Originally Posted by GT Motoring II
Originally Posted by RedCelica' timestamp='1366825157' post='22496396
I hear you can get some stiffer springs for the DFVs and they dont require a revalve. Would be nice to throw some 12/11k on them.
You can. We sold some recently with 650lb, 550lb springs.
very interesting....
Old 04-24-2013, 10:50 AM
Former Sponsor
GT Motoring's Avatar
Same setup //steve\\ is running
Old 04-24-2013, 10:52 AM
//steve\\'s Avatar
yup. I'm running 650/550 on mine with no issues at all and like it better than the off the shelf rates.
Old 04-24-2013, 10:55 AM
RedCelica's Avatar
Are you nonstagger?
Old 04-24-2013, 11:01 AM
//steve\\'s Avatar
yup. And I also have an Eibach front sway I run on full stiff. OEM rear bar. The car honestly feels great. Only reason I was looking to possible up the rates was because a lot of the successful track/autocross guys run rates about where I wanted to be. I think I'm at a really good place that allows for dual use.
Old 04-24-2013, 12:00 PM
Sponsor
Urge's Avatar
You can also move the DFV front springs (572) to the rear and simply run 650s on the front. Only issue is different color springs front to rear..
__________________
Old 04-24-2013, 01:28 PM
RedCelica's Avatar
wonder how that rate would work for us staggered folks
Old 04-25-2013, 04:07 AM
//steve\\'s Avatar
With a stock front sway it would probably be fine. My change in rates have actually closed the gap on front/rear rate difference. It's around 120lbs difference off the shelf and I'm down to just 100lbs difference.
I wouldn't hesitate to run the car just like it is even on a staggered setup. Would probably ditch the front sway or at least back it down to the softer setting.
Old 04-25-2013, 05:27 AM
ViperASR's Avatar
That fact they can't do the higher rates is my only complaint about the DFV. Would love to be able to run something around 750ish up front and 650ish in the rear but I think it's just too much of a jump on the factory valving.
The AST out of the box is probably able to take a little more spring without a revalve.
I've got 4150s that are ready to install with 650/550. I'm going to run them like that for a bit, and then maybe put the 650 in the rear and pick up 700 or 750 for the front and give it a try. I wanted to do 700/600 originally, but we couldn't get a 600# spring for the rear in the size we wanted. Note this in on a non-stagger car with a big front bar and the Miata rear bar.
I think the valving on the ASTs are supposed to be good for up to around 900#. I don't get my panties all excited for dyno plots, shock builders know a lot more about the shocks and can offer better insight. I'm tempted to get mine converted to 4250s when it becomes available, but time will tell.
Don't tell Austin at GT Motoring that I haven't installed them and already am thinking of screwing with spring rates within the next few months...
Quick Reply: Ohlins DFV Shocks installed
