Pad for street
They don't bend unless your hubs are bent or you torqued your lug nuts with a jackhammer or you dropped your car on them.
Splashing a puddle in Florida doesn't bend a rotor. Cars are not that fragile or nobody would drive them.
Your pads probably are a ceramic compound. They likely got too hot and smeared themselves all over the rotor. That causes vibration. Resurfacing only fixes it temporarily.
Buy new rotors. New rotors are under $20 on Amazon and Rockauto. Raybestos or Centric...whatever.
Buy pads that don't suck.
MOST commonly available ceramic pads are garbage.
Unfortunately, you want low dust (not sure why). You could open up a world of excellent, inexpensive pad choices if you were OK with some dust.
If you are stuck on low dust pads...then, yes, the Powerstop Z line works fairly well. I would probably opt for the Z26. They're like Z23's but with a better coating or something? Idk.
Will check on the discs because I have never seen them for $20.
check on rockauto.
Here is my thought process on brake dust:
As you stated...it rains 8 days of the week in FL.
If the wheels get dirty in the 2 hours between rain storms...maybe its not really a big deal?
The whole car gets dirty when it rains. Usually, when I clean the car, I clean the wheels too...
My personal solution for dusty wheels is to just not look at them. ZERO dust that way.
I won't recommend any pads that will stain your wheels. I use pads that create dust....but it washes right off. Is that something you'd be interested in?
Are you actually planning on tracking the car? Or just driving it kinda hard on the street?
Just asking so that you can get a recommendation that actually works for you.
check on rockauto.
If there is the opportunity for a track day I may go.
Dust. Well not crazy about dust. But some pads stain the wheels pretty bad.
I don’t go to track. Only street. Only drive car on Fridays and weekend, often a few miles. But yes, often hit the gas and am a bit hard on brake if needed.
Stoptech 308 (street) will be better on the street for sure. But they won't really work on the track.
aCab
01-20-2011 01:06 PM
ACLR8
03-07-2004 04:24 AM
