Roll Center Adjuster lowering
So I know if you through roll center adjusters on the car it lowers the control arm and therefor the shock essentially mounts lower. If you did this on totally stock suspension what would happen? Say I just want a little lowering but nothing else? Or if I wanted to combine them with a lowering spring so that I wasn't on totally bottomed out stock shocks. Is it possible?
Roll center adjusters would lower a stock car keeping the same usable travel at the damper as it would be without roll centers.
You might have issues with wheel clearance in the front, the rear shouldn't have any issues.
You'd also gain a slight bit more dynamic camber, I don't think static camber gain would be measurable though.
I may be thinking this incorrectly but if you lower the car you throw your roll center off and increase body roll, but if add the roll centers without dropping the car with springs you will move your roll center up and throw off the cars balance? not sure if that makes sense
But roll center adjusters also lower the car because of the way they move the lower control arm down. If you through them on a totally stock s2000 it would sit lower than stock.
kt411gcn
02-28-2019 11:41 AM
