Sponsored by: Sake Bomb
S2000 camber kit needed ?
Old Feb 4, 2013 | 06:45 PM
jdmsti23's Avatar
Default S2000 camber kit needed ?
Car is slammed on bc coils and finally got time to do an alignment the tech who did the job says I need a camber kit because there's not much he can do . After the alignment not much changed here's how the camber is now
Left front -0.4
Caster 7.6
Toe0.04
Right front -1.2
7.3
0.04
Left rear -2.6
Toe0.10
Right rear -3.1
Toe 0.09
I'm not an expert but its seems like they could have done a better job don't know why there's so much difference between sides I might need a camber kit to get to positive camber but shouldn't camber be equal or very close on both sides what do you guys think ??
Old Feb 8, 2013 | 02:31 PM
Pariah's Avatar
1) You need to go to a different alignment shop.
2) You do not want positive camber.
The guy should have the camber settings equal from side to side. Within .1 is acceptable. If you take it elsewhere and they can correct the problem, you need to print out the new settings and bring them back to the first shop and demand your money back. If they cannot correct the problem then you have some bent/damaged parts.
jdmsti23
Feb 5, 2013 09:12 PM
Flapjack
Mar 29, 2011 10:42 AM
pputkowski
Jan 21, 2009 12:38 PM
rj2000
Nov 29, 2008 09:17 AM
elude
Oct 14, 2005 01:32 AM
