VGS steering wheel
VGS steering wheel
is there any S2000 MY where it is a direct fit?
how are the splines different from our colum shaft splines
what is required to make it fit?
Many thanks!
for the record:
found this already
https://www.s2ki.com/forums/index.php?showt...&#entry13945243
but still doesnt tell me what the real difference is
found this already
Its only a direct fit on VGS cars, wich im pretty sure are only in japan. The only diff is the splines on the hub and the plastic parts on the wheel. Im gonna give you the benefit of the doubt and say you figured out what it takes to make it fit.
S2kpuddydad does the coversions and is very good at it
its not a cheap switch though
the wheel is expensive IMHO and the work needed is critical and time consuming
personally I dont like the mod unless you have a VGS model
I have the wheel and I compared to the OEM wheel splines and cannot see any differences jsut from having a look.
Thats why I ask.
when I have time will take a closer look but I thought maybe someone knows already.
Thats why I ask.
does anyone have a pic of the VGS's splines? I'm trying to compare it with another wheel i have for my prelude... I want to know if it will fit on my 4th gen prelude pretty much.
I know the USDM S2000 wheels fit perfectly on the 5th gen prelude, but not the 4th gen prelude.
I'm curious to see if the VGS wheel may be a direct bolt on to the 4th gen prelude's steering column spline.
D2 TEX
12-22-2010 11:58 AM
jwfisher
04-27-2002 03:40 AM
