Sponsored by: Sake Bomb
Why does the same suspension feel different
Old Jan 28, 2010 | 11:39 PM
macr88's Avatar
Default Why does the same suspension feel different
Why do I feel like the motion ratio is different in the rear.
I hope I'm using that term correctly, basically the leverage the wheel has on the shock.
Is it different?
Old Feb 2, 2010 | 07:37 AM
jeffbrig's Avatar
I assume you mean springs/coilovers when you say "same suspension". Sway bars are the other major element in suspension feel, and sway bars size/thickness has changed every couple of years on the s2000. So even with the same spring/coilover setup, you don't have the same overall suspension feel.
Old Feb 2, 2010 | 07:52 AM
macr88's Avatar
Just driving straight over bumps, the AP1 feels more compliant. Regardless of compression and rebound settings.
Old Feb 2, 2010 | 08:00 AM
jeffbrig's Avatar
Sway bars affect vertical travel of the suspension, they're coupled to the lower suspension arms. When the wheel to travel up and down, you're flexing a big steel bar. That alone can cause something of a different feel. A 300# spring with a heavy, stiff sway bar is going to feel different than a 300# spring with a thin, flexible sway bar.
Another possiblity is that you have an 07. Somewhere along the line there were also some other tweaks made to control bump steer, your 07 may very well have that change as well. You may want to search for deatils on that change and see if that could be a factor.
robrob
Jul 13, 2016 01:06 PM
Danwolski
Feb 20, 2014 11:53 PM
TwoFourty
May 12, 2006 04:21 PM
mingster
Mar 18, 2001 05:03 PM
