00-01 S2000 Tweeter Mounts
Old Apr 22, 2011 | 12:19 AM
javalotte's Avatar
Default 00-01 S2000 Tweeter Mounts
I bought component speakers - Polk Audio DB6501's - and want to install them on an 01 S2000 with no stock tweeter mounts. Doing a search, I came up with the best looking mod by darkknight1999:
https://www.s2ki.com/s2000/index.php...&f=26&t=351945
This is something I want to shoot for. But this was done with a newer S2000. The Polk components come with flush mounts for the tweeters, but I am worried about the clearance on the driver's side at the stock tweeter location. I've also seen this as a viable alternative:
https://www.s2ki.com/s2000/topic/380...1#entry7494360
Which is nice, but requires dremeling the leather on the panel, which I have NO IDEA how to do cleanly. The tweeter also doesn't create a good sound stage because it's literally under the dash. What I don't want to end up doing (no offense) is:
http://home.comcast.net/~robinette/T...iverDoorSm.jpg
because I'm a clumsy oaf and I would probably knock the mount off the panel by accident.
I'm considering the A-pillar but that would mean I would have to route wires from the crossover unit in the door panel back to the dash, which seems like a pain. Dremel in the stock location and cross my fingers that the tweeter depth will clear the panel? Any other suggestions?
Old Apr 24, 2011 | 01:27 AM
javalotte's Avatar
Went ahead with the dremel. Took about 30 minutes to make the holes, another 30 to clean up a bit.
Left side:
Right side:
The right side mount isn't as flush as I would like it to be because the plastic moulding is curved. The tweeter housing actually cracked a little because I was screwing the mount in so tight to try to get it to sit lower.
I know I'm 10 years late to the party, but this board has been really helpful, thanks
Cheers,
Old Apr 24, 2011 | 08:39 AM
NDAZONE's Avatar
Looks good!
Old Apr 24, 2011 | 12:20 PM
G's Avatar
G
Nice install - good job. How is the sound?
Old Apr 24, 2011 | 04:37 PM
javalotte's Avatar
Sound is good. I got a Pioneer DEH-7300BT with an axxess aswc steering wheel control adapter. Not the best headunit, but I can hear it clearly with the top down at highway speeds so I'm satisfied . The tweeters are a bit bright though, probably because the passenger one is pointed directly at my ear when I sit in the driver's seat. Pretty good sound for a low-budget setup. Would highly recommend it.
Old Apr 25, 2011 | 10:20 PM
SIchodelic's Avatar
that looks OEM
awesome job bro!
Old Apr 26, 2011 | 10:33 PM
javalotte's Avatar
Actually I need some advice. When I turn the stereo up, the speakers start distorting at high volume (at volumes necessary at 50 mph with top down). Shouldn't these polks (100W RMS) hold up to the output of the headunit (4x50W) ? Could the headunit not be powerful enough and thus sending a dirty signal causing the distortion?
Thanks,
Old Apr 27, 2011 | 07:58 AM
oth's Avatar
oth
Usually distortion is caused by pushing an amplifier (in this case internal to the headunit)
to produce more power than it is designed to.
Most aftermarket speakers are less efficient (though better-sounding) than the OEM ones, so
they require more power, and your headunit is probably capable of less than 20 watts RMS per
channel (50w is likely peak), so I'd bet you need "more power, Scotty!"
Old Jul 10, 2011 | 11:07 PM
unison21's Avatar
This is exactly right. If you use just the headunit to power the speakers, you will get clipping (distortion) at high volumes where the power of the headunit (measured in RMS, not Peak wattage) is not enough to power the speakers.
BTW, nice job on the tweeter install.. I'm aiming for something like that.
Old Jul 12, 2011 | 07:28 AM
Boost-Me's Avatar
Nicely done on the passenger side. My alpine tweeter mount was a little bigger and I ended up with a little bit of a gap on the top of the mounting ring. Again, looks good!
blue280z
Jun 5, 2012 09:23 AM
tmkpres
Aug 19, 2009 05:11 PM
SlidinS2k
Dec 13, 2005 06:09 PM
Purge
Oct 31, 2001 08:37 AM
Moely
Nov 2, 2000 07:22 PM
