04+ tweeter Grills
Old Jul 7, 2005 | 02:32 PM
lude2S's Avatar
Default 04+ tweeter Grills
I was at my local auto installer yesterday and he was saying that for mounting the tweeters from my compenent set i can just go to honda and order the 04+ tweeter grills and get them cut into my 01 door panels. Just wondering if anyone has done this and if there were any real changes in the design of the 04+ door panels that makes this idea not feasible.
Old Jul 7, 2005 | 07:14 PM
darkknight1999's Avatar
I'm not sure about the '04' model tweeter pods, but I can tell you this. I have Carbon Fiber upper door panels and I had to cut in my '02' tweeter pods and I did it with a fair a amount of ease.
I'm just trying to remember if the '04' cut in as easy... I would think so but for some reason I think they are a little harder to fit properly...
Old Jul 7, 2005 | 11:18 PM
YuriArts's Avatar
I installed my Alpine tweeters a few weeks ago in my '00 S2000, no problem.
I think the '04 tweeters are a bit bigger so they will have to fit high in the door.
Mine are just behind the door handle.
I don't think there are any changes made to the layout of the door (inside or out).
So installing them won't be a problem.
Old Jul 8, 2005 | 04:47 AM
lude2S's Avatar
Ok, thanks guys. I'm gonna go ahead and order these grills and give it a try.
Old Jul 8, 2005 | 05:02 AM
If your just going to cut them in you should be fine. I did the research and if your trying to retro the 04 into a 02 it doesn't work but you should be able to install those fresh with no problem.
Old Jul 8, 2005 | 02:11 PM
lude2S's Avatar
Ok, sounds good. Yeah i'm not doin any retrofitting, just cutting them into some 01 door panels. Thanks for your help.
Old Jul 8, 2005 | 02:43 PM
If you have someone in your local club with an '04' I would ask if you can make templete from their door panels, that way you'll place them in the exact right spot.
Old Jul 8, 2005 | 10:01 PM
lude2S's Avatar
unfortunately there aren't many s2k owners here locally in Manitoba, but i may just go see if i can find a dealership that has one in stock and i will also get a print out from honda.
brianc555
Aug 29, 2007 03:35 AM
PhenomS2k
Nov 14, 2005 07:31 AM
alexpilot
Sep 14, 2005 12:42 AM
ThaWyze1
May 17, 2004 10:30 AM
SS2000
Nov 22, 2003 05:18 PM
