06 S2K Factory Alarms Questions....
I had a 06 S2K and couldn't find the alarm box anywhere in the car...I thought it's suppose to be under the driver's seat. I checked and it was not there..I'm trying to wire my own L.E.D. lights...
Any helps are appreciated..
Are you sure your car has an alarm? You have to pay extra for the alarm -- the car only comes with keyless entry system. Of course, easiest way to check is just sit in the car, arm the system using remote, and open door from inside.
Anyway, the factory alarm is located under the driver's seat. You should also see a bunch of wires running under the seat if you have the factory alarm, and only one wire if you don't have an alarm.
Originally Posted by bluefever06,May 26 2006, 09:37 AM
ohhh, i thought the car comes with an alarm..nvm...
thank you Ks320....
thank you Ks320....
Ya ... it fools a lot of people. You can get the OEM one from websites (ie. from some of the s2ki sponsors, or other Honda accessories sites like www.handaaccessories.com) if you don't want to spend too much or if you don't want to spend many hours installing an aftermarket one. The OEM one is relatively easy to install.
Peace
PS. Dang! Your bike + S2000 in blue look hawt!
Originally Posted by Kingsta18,Jul 19 2006, 01:16 PM
are there any good threads with pics on installing the 06 factory alarm?
Here it is:
http://handaaccessories.com/S2000/06security.pdf
Originally Posted by rworne,Jul 19 2006, 02:55 PM
handaaccessories.com usually has pdf files of the installations next to their products.
Here it is:
Here it is:
