12v outlet problem
Old May 20, 2011 | 12:15 AM
teggytegteg's Avatar
Default 12v outlet problem
So heres the deal, when my radio is on and i plug my cell phone charger the radio turns off. Also instead of chargeing my phone it drains my phones battery. What could be the problem?
Old May 23, 2011 | 06:04 AM
takeshi's Avatar
Specs on the charger? If you're not supplying more than you're using you'll drain your phone's battery. You should sort out the existing issue with the head unit first though.
Old May 23, 2011 | 02:51 PM
Not sure of the specs since i bought a univetsal charger, but ill check behind the head unit and see if any wires is touching each other. Thanks for the help hommie
Old May 24, 2011 | 08:05 AM
SgtB's Avatar
Is the charger shorted out? What size fuse do you have in the radio slot?
Old May 24, 2011 | 08:18 AM
dwight's Avatar
Does the charger work in another car? Do other 12v devices work in your car?
Old May 24, 2011 | 09:31 AM
SgtB: charger is not shorted out and im not sure what size the fuse is on the radio..
Dwight: yes the charger works in othe cars and no other devices will charge.. well they do but instead of chargeing it drains the devices battery
Old May 27, 2011 | 06:21 PM
dwight's Avatar
Any luck fixing it?
Have you inspected fuse #9? It is for the accessory outlet and radio remote switch.
Does the HU always turn off when you plug in a device into the accessory outlet? Is so, do you have any devices which draw no power that you can plug in? e.g. plug or splitter. Do you have a voltmeter that you can use to check the voltage of the outlet?
[strike]Do you have the stock head unit? Have you tried seeing if the 12v outlet works when the HU is removed?[/strike] (note: I don't think these are likely an issue. It probably has to do with the wiring in the accessory outlet or fuse #9.)
Gen0ss
Aug 5, 2016 06:30 PM
jacobzking
Jan 27, 2013 11:10 AM
Bigbaddie
Dec 13, 2012 03:12 PM
Smitty2k
May 11, 2010 07:55 AM
brody13
Oct 14, 2008 10:38 AM
