2 questions regarding Kappa Perfect 6.1s
Old Jan 29, 2007 | 12:23 PM
Thomp's Avatar
Default 2 questions regarding Kappa Perfect 6.1s
I finally broke down and picked up a set of Infinity Kappa Perfect 6.1s. I also have some RAAMmat to go with it. The full install is coming this weekend.
In the meantime, I've started gathering everything I need, and yesterday I went ahead and cut the baskets from my factory speaker holders. Here are my two questions:
1) Now that the factory bracket has no rain guard, do I need something behind the new woofers? I'm thinking something like the foam basket things, but the local audio shop says they are a waste of time.
2) The fancy clear plastic cover on the crossovers seem like they would rattle. Do I leave the covers on them or take the covers off? (I'm going to mount the x-overs in the door cavity)
Now I have to come up with a way to mount a second amp!
- Thomp
Old Jan 29, 2007 | 01:02 PM
darkknight1999's Avatar
You can get a set of XTC foam baffles, but cut a small slit the size of your little finger in the bottom so the speakers can breath. As for the crossovers, I don't like leaving in the door, but if you really feel you must, leave the covers on. Mount the x-over in the spacer bucket in the door. You'll need some velcro for that.
Old Jan 29, 2007 | 01:05 PM
Thomp's Avatar
I was just thinking mounting them in the door would keep the wire runs down a bit. Is there a more recommended place to put the crossovers?
Old Jan 29, 2007 | 02:09 PM
I always put them inside the car. Its safer for them and if you want to adjust the sound you don't need to take the door panel off
Apex1.0
Apr 30, 2014 09:02 AM
winter5470
Oct 11, 2012 04:47 PM
mcraghead
Dec 29, 2008 12:12 PM
swerveking
Sep 12, 2008 02:09 PM
Ron H
Apr 10, 2003 06:51 PM
