4x oem alarm/keyless range.
Old Sep 3, 2007 | 04:29 PM
  #31
Stealth_SUX_'s Avatar
Or do what i did, install a viper 1 mile 2 way alarm..
with shock, window and motion sensor..
Old Sep 4, 2007 | 05:46 AM
  #32
Lovetodrive2000's Avatar
Originally Posted by asukadc,Sep 1 2007, 04:03 PM
what exactly did you do? u found that wire/antenna, clipped and just tie on it? where did u put the rest of it? got pics?
The antenna wire that sticks out from the front of the control unit under the drivers seat is maybe 12-18" long. Just straightened it out and it reached maybe 3" past the front edge of the car seat.
Clipped the little end cap off, stripped the wire back 3/4" and took a 24-36" piece of speaker wire, then connected the two with a wire nut.
Ran the wire back under the seat and then up along the back of the seat, and wrapped it around that little plastic hook behind the seat....
Working like a charm!!
Old Sep 4, 2007 | 07:07 AM
  #33
neoarroyo's Avatar
Originally Posted by iam7head,Aug 31 2007, 11:15 AM
you have that option in OEM optional alarm, you can neither have the alarm turn on but not lock the car OR you can have the alarm on and have it lock the car.
i think the delay is 30 second from the point you remove the key or from closing the door, i can't remember which.
So, you're saying that when I park the car, get out, close the door, but forget to lock it and walk away...that the OEM alarm has an option to self lock after a set amount of time? If so, where and how do I set this option?
Old Sep 4, 2007 | 11:00 AM
  #34
GrandMasterKhan's Avatar
No.
If your car is CURRENTLY LOCKED> and you unlock it, but fail to open the door withen a certain period of time. The car will relock the doors.
Old Sep 4, 2007 | 11:55 AM
  #35
neoarroyo's Avatar
Originally Posted by GrandMasterKhan,Sep 4 2007, 11:00 AM
No.
Ah, I wonder why they didn't give us the other option instead where if I opened door/closed door and walk away, then it self locks/arms. I would think that that would be way more useful than the current autolocking feature, it just seems like a pretty useless option to have. I can't think of a situation where I would walk up to the car, unlock it, but not open the door and walk away...
Old Sep 4, 2007 | 01:07 PM
  #36
S2Koupe's Avatar
actually with my aftermarket alarm, i thought the auto arm/lock feature would be great. but i found that it sucks when you have to fill up at the pump.
i guess i could keep the key in the ignition while i pump. but i dont like the possibility of me being able to lock myself out of my car at a gas station....
Old Sep 4, 2007 | 01:31 PM
  #37
asukadc's Avatar
is it visible without pulling the seat out? do i need to pull the carpet a lilbit? where is it under the driver seat, near where the airbag sensor thing is? the lil connector to the seat
Old Sep 4, 2007 | 05:35 PM
  #38
neoarroyo's Avatar
Yes, it is visible under the seat, in fact it is just below the edge of the seat. If you sat in the driver's seat and reached under, you'll feel it.
Old Sep 5, 2007 | 04:17 AM
  #39
The Honda installation instructions (http://www.handa-accessories.com/S2000/s2ksecurity.pdf) show the antenna attached to a clip in front of the actual unit. Mine was not, which madfe it easy to pull it forward.
Look at the installation instructions link above to show placement....
Old Sep 5, 2007 | 07:13 AM
  #40
asukadc's Avatar
thanks for the pdf!!
but now i got a new question... i didn't see the control unit under the seat when i pulled it out for my spg... i wonder where the thing is now..
