5A Fuse Keeps Popping
Old Jan 16, 2012 | 09:54 AM
JawKnee's Avatar
Default 5A Fuse Keeps Popping
I have a fuse holder, currently with a 5A blade fuse, plugged into the "accessory" tap/port on the interior fuse box. Now connected to this fuse holder is my PLX AFR gauge, my V1 radar detector, and some heated seats. I need to confirm, but each item may have its own fuse before coming together to the 5A fuse holder going into the tap -- hopefully the configuration makes sense.
Everything works fine, but usually when I turn on the passenger heated seat (can't recall if the driver's has to be on too), the 5A fuse pops.
How should I remedy this? I can't simply add a bigger fuse (say 10A) at the fuse holder without any cause for concern can I?
Old Jan 16, 2012 | 07:01 PM
eastcoastbumps's Avatar
It depends on the size of the wire and what kind of amperage the heated seats draw. I'm sure they're pulling more than 5 amps. You should run them on their own circuit, either right from the battery with a fuse next to the connector, or off a higher amperage feed from the fuse box.
Old Jan 16, 2012 | 07:21 PM
TPhong's Avatar
^ I agree!
Old Jan 16, 2012 | 08:51 PM
JawKnee's Avatar
I couldn't figure out the amperage of the heated seats, so any idea on what higher amperage feed from the fuse box I can or should use?
Thanks for the input guys!
Old Jan 17, 2012 | 04:46 AM
takeshi's Avatar
Do you not realize the problem with your question?
Who makes the seat heaters?
Old Jan 17, 2012 | 07:31 AM
JawKnee's Avatar
No
I believe these are the ones: http://www.seatheater-heatedseats.co...OVMTC=advanced
Old Jan 29, 2012 | 08:22 AM
steven975's Avatar
your heated seats are drawing more than 5A. You could use a 10A fuse (for all devices) and see if that works. If the fuse still pops, you should run a wire from the battery (with a fuse at the battery) and then relay it into the ignition lead.
Old Jan 31, 2012 | 01:11 PM
Will's Avatar
Each seat will draw a max. of 5A. You need a 10A circuit or better yet, 15A for all those devices if you insist on running them on the same circuit.
Old Feb 1, 2012 | 09:01 PM
JawKnee's Avatar
Any reason(s) why I wouldn't want to run them on the same circuit?
Thanks for the input fellas!
Old Feb 2, 2012 | 11:35 AM
Will's Avatar
If the circuit you were using originally used a 5A fuse, the wiring supplying power to that location uses a sufficient gauge to deliver enough juice for 5A of current. If you use a different fuse, the resistance of the wiring could potentially generate enough heat (under load) to melt the insulation on that wire, create a short, and start a fire. Granted, that is a worst case scenario... but I wouldn't want to chance it if it were my car. If it were me, and I was installing an aftermarket seat heater, I would run a new power cable from the battery to an aftermarket fuse panel where I could use whatever gauge of power supply wire I wanted, with whatever size fuse I wanted.
