Acessory Wire Pain In the A$$
Old Jul 24, 2008 | 05:33 PM
vtec4life's Avatar
Default Acessory Wire Pain In the A$$
Well my radio was working fine until I pushed all the fuses in to make sure they were tight on the fuse block now the fuse block is getting power for the acessory wire but it's not getting power to the radio or cigarette lighter and the circuit city technician said i would have to replace the whole wire from ignition to the radio BUT the fuse block has power just not the radio harness? Any input would be great right now! Thanks.
Old Jul 24, 2008 | 07:31 PM
darkknight1999's Avatar
Do you have a stock HU or an aftermarket HU?
Old Jul 24, 2008 | 09:32 PM
vtec4life's Avatar
after market i think I figured it out, the acc. wire is not getting power after the fuse box making me believing it's the acc. relay, does anyone have a diagram or can guide me to where this relay or ig2 pgm relay is?
Old Jul 28, 2008 | 07:34 AM
Cubs2k's Avatar
Not to sound silly.....but no power after the fuse box usually = bad fuse.
Here are some other questions.....what do you have running off the acc wire?
Does your 12 acc plug work? You know....the one near you elbow when you are sitting in the car.....the lighter socket.
Old Jul 31, 2008 | 07:36 PM
vtec4life's Avatar
the stero power acc wire nor does the socket work, the fuse is fine and has been replaced just in case and still no power so what I did was tap a wire into the acc wire behind the fuse box directly to the radio acc and now everything works!
yourboysoap
Apr 22, 2022 05:19 PM
aphex4000
Aug 14, 2010 03:48 PM
captainbk
Dec 3, 2006 07:00 AM
LiQUiD iCE
Apr 12, 2005 06:20 AM
stockae92
Jan 16, 2003 12:05 AM
