addition front and sub speaker choices...
Old Apr 23, 2001 | 12:03 PM
shingles's Avatar
Well I am sure many know the search for the front 6.5" and subs that will fit without much cutting can be difficult. Today while visiting one of my buddies shop(carries some higher end stuff) we came across a few addtional choices...
Planet Audio has the following products that I am looking at:
P65NEO:
6.5" two way with detachable tweeter
Power handling(RMW): 100 watts
Carbon Fiber woof cone
1" titanium dome tweeter with neodymium magnet
Butyl Rubber Surround
Efficiency(1watt/1meter)91 dB
1" Kapton Voice Coil
Super Neodymium magnet
get this: Mounting depth 1-3/4"
There's a P68NEO:
(difference)
1" soft dome silk tweeter
1-1/2" voice coil
150watt rms
component set
crossover slow: 18dB/Octave at 4500Hz
depth 2.25"
The sub I am looking at is the follow:
P8NEO:
150watt RMS
cast aluminum basket
carbon fiber cone
platinum plated 3 wat binding posts
efficiency(1watt/1meter): 90dB
2" aluminum voice coil
neodymium magnet
and a mounting depth of 2.25"(that's NOT a type-o).
I am going to run this with two Lunar 60X2. One for the speakers up front and one bridged fro the sub. The sub is shallow enough for me to mount behind passanger seat I think. Amps will probably go in the back.
The speaker will/should be out end of this month. Cost is not bad either... the 6.5" P65NEO is around $200 and the 8" sub is about $150. The amp is the killer(to me) at $350 each.
-Shing
Old Apr 23, 2001 | 02:29 PM
ricosuave's Avatar
just because it has a shallow mounting depth still doesn't mean you don't have modify the speaker basket. you still might have to accomodate for the magnet.
Old Apr 23, 2001 | 02:35 PM
shingles's Avatar
yup, well aware of this.. but it's pretty prmising because it dosen't appear to be that large. will have to see once I get the speaker at hand.
Hey, atleast this is one less dimension we have to worry about.
-Shing
Old Apr 24, 2001 | 02:07 PM
flava's Avatar
Those amps are awesome. i've got the same thing driving some Focal 165K2's. bad install though.... argh....
jayboi78
Jun 19, 2008 05:18 AM
MugenRioS2k
Dec 10, 2006 06:47 PM
jtech56
Jun 29, 2005 07:01 AM
phillys2k
Mar 29, 2005 09:53 AM
Jaysom
Apr 4, 2002 09:19 AM
