AEM Uego Help
Old Sep 6, 2005 | 06:28 PM
folex187's Avatar
Default AEM Uego Help
Are there any places within the cabin (ie fuse panels) that I can tap into for power on my AEM Uego. I was thinking about the lead that I use for the relay to my Aftercooler pump:
Will this work or do you have another suggestion? Also where would I find a good ground?
Old Sep 6, 2005 | 06:56 PM
xviper's Avatar
Yes, the one your arrow points to will work. You will find a ground if you look up from the fuse box under the dash. You'll see a bolt in the frame with an "octopus" of black wires going onto it. That bolt or any of those black wires will be a good ground.
I did what you were thinking of doing. I used the relay for the intercooler water pump for the power tap (same hot lead that goes to the pump). I used one of the ground bolts in the engine bay for ground (actually the same ground as for the pump). This is probably a better way since is gives you direct power feed in the engine bay, instead of having to go through another fuse panel.
Old Sep 6, 2005 | 07:02 PM
folex187's Avatar
Ya, I think a relay would be best. Maybe I'll take a trip to radioshack tomorrow and see if I can find something small.
Old Sep 6, 2005 | 07:15 PM
xviper's Avatar
Why don't you just splice it into the water pump relay. It can handle it. I've had mine that way for months.
Old Sep 6, 2005 | 09:22 PM
folex187's Avatar
I would but the water pump relay is located inside the front bumper with the comptech kit.
05TurboS2k
Nov 3, 2018 12:01 PM
4U2NVmyS2K
Feb 10, 2015 07:24 PM
Ap2low
Jan 15, 2015 05:10 PM
crash
Sep 1, 2013 08:33 PM
sbrodacz
Mar 23, 2009 03:36 PM
