AEM meth/water injection kit installed
I've searched and searched and have only seen joeyballs how to on the aem meth injection kit. I'm almost done with my install and plan on doing a write up on it. Overall the process is fairly straight forward. I took out the jack and mounted the bottle there with the pump right below it. Next, I attached the controller. I placed the controller in the passenger side under the dash. Next, I ran the wires that are need to be connected to the pump and bottle from the controller. White, Orange and Brown need to go to the bottle and pump. Very easy. Next I decided where I wanted to mount the green led. The gray wire connects to the led and then the other wire on the led needs to be connect to a power supply. I then installed a 12 volt switch and connected the yellow wire to it. Next is getting the three wires that need to be connected to the battery out into the engine bay. I ended up drilling a little hole and fed the wires, vacuum line and hose for the meth through it. I'll end up using some caulk to seal around the hole. I then ran the meth line and taped a 1/8" hole for the nozzle. Last I taped into a vacuum line. I'll post some pictures tomorrow when I get a chance. If anyone has any questions please feel free to ask. I will not have any numbers until the 7th of April.
