AEM X series CAM BUS gauge help
Recently bought the AEM X series CAM BUS gauge as it is capable of reading multiple stats from the AEM series 2 I have in the car. I currently have a PLX devices Wideband and controller, was hoping that this gauge would read that as well but it seem it will only read AFRs from the AEM Wideband sensor itself. Is anyone running this gauge and can verify if indeed it will only read afrs from the aem Wideband? Just want to make sure before I purchase the AEM Wideband that there is no way to make the gauge read the PLX Wideband (side not the PLX is obviously tied into the ecu and confirmed it is working properly)
Odd question, the gauge connects directly to the AEM ECU as it reads multiple parameters directly from the ecu. All other parameters it is supposed to read work properly except AFR, heard recently there might be something in the software to turn this aspect on but that is why I am reaching out in hopes someone else is running this same gauge.
