after replace my battery, sub is kinda weak
Old Aug 21, 2007 | 03:26 PM
fflatulip's Avatar
Default after replace my battery, sub is kinda weak
after replace my battery, i had a little noise coming out of my front speaker, i shut the car and turn on again, it turns fine.
but now the sub is kinda weak, how do i fix this
thanks
Old Aug 21, 2007 | 03:45 PM
WLAURENT's Avatar
What head unit are you running?
If you had the sub-output gain turned up in the head unit - it likely defaulted to 0 on reset. You sub channel may not even be on or outputting a sub signal.
Need more info or you need to find your HU manual and start tweaking all your settings.
Old Aug 21, 2007 | 05:46 PM
imdarkrider's Avatar
sounds like you didn't let the system discharge correctly when you replaced the battery... or what laurent said - check that first.. then try properly discharging and re-charging the car... you might have spiked the amp.
Old Aug 21, 2007 | 10:58 PM
fflatulip's Avatar
the head unit is KENWOOD KDC-X869, i set back all my previous settings, not seems to be fine, tho still feel a bit weak in base, probably just my ear problem..haha
thanks so much guys
X100
Nov 25, 2013 11:46 AM
DangerZone9K
Mar 28, 2012 07:40 AM
philipf22
Feb 23, 2006 01:54 PM
C4SxM5
Jan 25, 2006 03:25 PM
ruexp67
Jun 2, 2005 07:16 PM
