Aftermarket Headunit Harness
Old Dec 3, 2009 | 05:18 AM
jason_v2's Avatar
Default Aftermarket Headunit Harness
Hey guys,
I had a 2000 Civic hatchback that I installed an Alpine CDA-9886 in. Does anyone know if the same pigtail harness (connected to the headunit) will work in a 2005 S2000?
Also, I'm thinking about routing my iPod cable to the mini "shelf" in front of the passenger side seat. Any cons for doing it this way? I did a little reading and it seems like if I just remove the passenger side panel next to the radio I should be able to fish the wire out. Is this correct?
Thanks!!
Old Dec 3, 2009 | 05:21 AM
jason_v2's Avatar
I checked on Crutchfield and as far as I can tell, their system is recommending the same harness for both cars. Can anyone confirm this?
Old Dec 3, 2009 | 06:15 AM
Scooterboy's Avatar
I would like to know if the OEM door will still close with this unit installed.
Old Dec 3, 2009 | 07:36 AM
jason_v2's Avatar
i searched on google and found another post on s2ki where someone has confirmed that the door will close with the 9886. any ideas on how to route the ipod cable to the passenger side "shelf"?
confirming thread:
https://www.s2ki.com/forums/index.ph...c=705153&st=0&
Old Dec 3, 2009 | 09:15 AM
2big4aS2000's Avatar
yes, yes ,yes. you will have to use the brackets off the factory headunit, and if door hits, adjust (make holes oval) and set the radio back unit it clears.
Old Dec 3, 2009 | 11:58 AM
Scooterboy's Avatar
confirming thread:
Fantastic. Thanks
In my '06 and '09 that shelf came out with two pins and a screw and was easy to route wires to near the back of the radio. I'd put it and see how hard it really is.
weenrock
Oct 21, 2017 11:33 AM
espelirS2K
Bay Area For Sale
Sep 18, 2011 07:22 PM
saaboteur
Jun 18, 2011 08:06 PM
Reds2kracer
Jun 17, 2009 01:18 PM
Trent06
Feb 18, 2008 08:53 PM
