Alpine 9827 or 9833?
Old Jan 28, 2004 | 07:10 PM
  #21
PJK3's Avatar
if it recommends the direct wire from battery and you're planning to use the internal amp, you'll have to seriously consider running that wire...
i can't tell you what i would do since i don't have to live w/ your consequences.
for me, it was a no brainer since my power draw was going to be so low (internal amp off).
Old Jan 29, 2004 | 06:46 PM
  #22
Calvin's Avatar
I have another question. Since I plan to add an amp later, should I run a larger guage wire from the battery to run the HU and then attach the amp to it later (probably a small amp to power 8" sub)? Can I do that? what can I use? Distribution Block? what guage wire then? will 10 or 12 ga enough? sorry for all these question. it's my first time installing anything. TIA
Old Jan 30, 2004 | 11:48 AM
  #23
PJK3's Avatar
run the wire from the battery when you install the amp. that way, you can size the wire based on what you're installing. and you'll only need a distribution block if you're doing multiple amps.
regarding wire size -- i find this guide to be very effective:
http://www.bcae1.com/wire.htm
and this calculator will 'run the numbers' for you, and tell you what gauge to buy.
http://www.bcae1.com/images/swfs/systemdes...gnassistant.swf
Old Feb 14, 2004 | 01:05 PM
  #24
zong777's Avatar
Can I use the stock changer with the 9827?
omgitsoop
Jun 3, 2007 04:20 PM
s2krazy01
Feb 23, 2007 05:45 AM
SlidinS2k
Nov 28, 2006 02:59 PM
s2k_redhead
Jul 28, 2006 01:22 PM
AustinS2k2003
Jul 14, 2004 11:14 AM
