Alpine 9857 Question
Old May 7, 2006 | 08:26 AM
adkboards's Avatar
Default Alpine 9857 Question
Just installed an Alpine 9857 with the Sirius tuner. Everything went great except that there is no sound for the Sat. The tuner and the CD work fine, but when you select sat. mode the display comes up and you can change and select channels, but no sound. The guy from Sirius said everything looks good on his end and the unit was set up and working properly. Any ideas?
Old May 7, 2006 | 01:39 PM
essess's Avatar
disconnect the unit at the brain box, plug it back in.
check to make sure you have switch power tapped in correctly, and a solid ground. Even tho your headunit displays sirius the unit may not be powering on.
Does it display the song titles that are currently playing when there is no sound? you may have a bad cord from the brain box to the headunit.
lemme kno.
Old May 8, 2006 | 04:25 AM
adkboards's Avatar
had the plug in the input instead of output, DUH!!. Thanks for the suggestions anyway.
smr22
Sep 9, 2010 02:34 AM
pville
Oct 1, 2007 09:17 AM
SPLNDID
May 12, 2006 02:19 PM
KaCee
Dec 21, 2001 09:59 PM
joecro
Aug 28, 2001 10:01 PM
