Alpine CDA-9833 question
Old Sep 22, 2004 | 10:34 AM
S2K@PR's Avatar
Default Alpine CDA-9833 question
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=13857
I was about to make the order and saw this on the webpage, and i know nothing about this type of installation...
"V-Drive hybrid MOSFET60 internal amp- High current draw requires direct fused connection to your battery"
Is this true ... do i have to make other connections so i can use this HU. Can someone with experience give some help.
Old Sep 22, 2004 | 10:41 AM
SCoach's Avatar
You don't need it. My Alpine is the same way, and I didn't do this. Been fine for 2 years.
Old Sep 22, 2004 | 11:26 AM
S2K@PR's Avatar
Oh ok you have a CDA9833 as well??
Thanks
Old Sep 22, 2004 | 02:35 PM
oatnet's Avatar
Yes, you REALLY need to do it. Don't pull the 14.4v from the Vdrive through your wiring. The factory wiring also isn't thick enough to handle the amps. Also make sure you GROUND it seperately - the factory wiring isn't up to handling the amps on the way out, either. If the other guys' Alpine is 2 years old I don't think it has the same current draw.
-JD
Old Sep 22, 2004 | 02:42 PM
DonTTgo's Avatar
If you don't plan on using the internal amp, then you don't need to run a seperate wire. Just use the stock Honda power wire. In fact you can tell the deck to shut off the internal amp in the settings. If you do use the internal amp you probably should run a seperate power wire so that it gets all the power it needs to perform at it's rated specs. Alpine only requires this on the decks with the vdrive amp, so they probably wouldn't just make it up. Otherwise it would probably perform as well as the 22 gauge stock powerwire that is however long of a run, permits it to. There is also a fan on the back of this deck that shouldn't be blocked. This deck also allows you to turn off the main display so that there is less power draw and less interference with the sound quality. This is a feature in some home A/V recievers too. I ran a seperate 10 gauge fused wire to mine. Wasn't too much more trouble. Hope this helps.
MuGeNKiiD89
Mar 1, 2009 07:25 PM
PaulR
Apr 13, 2007 12:27 PM
kikicha
Jul 23, 2006 09:12 PM
PokS2k
Jul 31, 2003 07:55 PM
S2kRob
Jul 16, 2002 08:19 PM
