Alpine CDA-9856
Old Mar 24, 2006 | 01:16 PM
nts2000's Avatar
Thanks man, I appreciate it.
Old Mar 24, 2006 | 01:35 PM
Will's Avatar
Originally Posted by nothing235,Mar 24 2006, 01:17 PM
I just completed my install of this head unit along with the IR DCI and an IPOD cable. It was a piece of cake to install, and everything works perfectly. However you have to mount the DCI's IR transmitter a bit further out because of the location of the receiver on the faceplate.
The one major problem I had was pushing the radio all the way in. I am running 5 RCA lines, along with all the DCI wiring, and ipod cable... It was tough to cram it all in there. Eventually I just pushed a 'bit' harder than I probably should have and now it all fits in nicely (some stuff is probably smashed though!).
I'll post pics in a seperate thread when my audio setup is complete, will be at least a couple weeks though. (Still designing a sub box.)
I had the same problem, even though I was only using 2 pair of rcas. The radio wouldn't go in all the way... so I lengthened the harness adapter so most of it goes under the radio, worked much better.
Old Mar 24, 2006 | 03:53 PM
nothing235's Avatar
And here it is, as you can see the paint and some of the heatshrink came off the IR sensor while pushing it through the hole. I plan on repainting it and using some heatshrink on the outside. I let a friend dremel the hole in the radio surround, its not toooo bad, but its the last time I'm going to let anybody touch something that goes on my car with a dremel!!! :-P
Old Mar 24, 2006 | 08:31 PM
nts2000's Avatar
THanks man. Now I have an idea of what it will look like?
Old Mar 25, 2006 | 07:57 PM
scho01's Avatar
Originally Posted by nts2000,Mar 24 2006, 11:50 AM
Does anyone know if it has the 3.5mm jack on the back of the unit?
Nope, but it does have an aux input though. You'll need to buy an RCA adapter for about 16 bucks. Then all you need is a cable that adapts RCA's to the mini jack and your good to go. If you have a changer, you'll need a more expensive adapter to split the two devices.
Old Mar 25, 2006 | 10:44 PM
ImBatman's Avatar
I was at an audio installer today and wanted to buy the IR for dash control on my 9856, he told me it was about $40 but $100 with install...i told him i would do it, but he said it was extremely difficult, is this true??? What was required to install??
TIA
Old Mar 26, 2006 | 03:00 AM
cshamash's Avatar
TIA
You would be best off buying Modifrys IR DCI. It is custom made for our car. But you will still spend around $100. It is very easy to install..
Old Mar 26, 2006 | 05:17 AM
darkknight1999's Avatar
Next time you should try putting the IR in a different spot and get someone without the shakes to use that Dremel for ya
I have the DJ Qubes audio control. It changes the why the controls work. You end up with the large button becoming a little joystick. It rocks!
Old Mar 26, 2006 | 05:25 AM
Exactly!
Old Mar 26, 2006 | 05:58 PM
virulosity's Avatar
Where can I buy Dj Qubes system from and find more information about it? Also, if I am using the ipod interface through my head unit, will the honda controls work the ipod?
